DFU Serial Number
2019-01-11 9:04 PM
I am looking at the code here that has the algorithm for producing the device serial number reported when the MCU is in USB DFU mode.
https://github.com/libopencm3/libopencm3/blob/master/lib/stm32/desig.c
The document they reference there, https://my.st.com/52d187b7, is now a dead link. Does anyone have the name of the document and its current location?
Bootloader
2019-01-12 6:19 AM
It's is likely are very old forum reference. Perhaps @brk or @Amel NASRI can dig it out
The interference here is this is a 6-byte contraction used by the System Loader. I would suppose you could quickly verify this by pulling the 96-bit unique ID for a unit and contrasting that with the reported serial number.
UM0424 doesn't really cover this
And the Get_SerialNum() here has an 8-byte implementation
2019-01-12 6:19 AM
2019-01-14 1:10 AM
The link is not a community link, perhaps @Amel NASRI can assist.
2019-01-15 12:06 AM
Yes this seems to be an old link in the platform used before migrating to Jive.
2019-01-15 12:31 AM
Unfortunately the "search" functionality now is less than stellar.
Does the System Loader do some contraction of the Unique ID?
2019-01-16 11:27 AM
The code I referenced does indeed match the serial number of the DFU serial number. I was just hoping to have an official reference to the algorithm I could point to. Finding dead links to a major developer resource like st.com is rather disappointing.
2019-01-16 12:13 PM
ST has gone through at least 4 forum softwares, a lot of content has been damaged or lost.
Unfortunately the cite in the code you provided lacks any title information so it's have to cross-reference via other means.
I don't recall the post or the functionality described in DFU related docs.
uint8_t *id = (uint8_t *)DESIG_UNIQUE_ID_BASE;
uint8_t serial[6];
serial[0] = id[11];
serial[1] = id[10] + id[2];
serial[2] = id[9];
serial[3] = id[8] + id[0];
serial[4] = id[7];
serial[5] = id[6];
2019-01-16 12:37 PM
"In all available demos in the “STM32 USB-FS_Device developer kit�? there is an example implementing a unique serial number string descriptor based on the STM32 Device Unique ID register (12 digits)."
Here from V3.2.1 does not look consistent
* Function Name : Get_SerialNum.
* Description : Create the serial number string descriptor.
* Input : None.
* Output : None.
* Return : None.
void Get_SerialNum(void)
uint32_t Device_Serial0, Device_Serial1, Device_Serial2;
Device_Serial0 = *(__IO uint32_t*)(0x1FFFF7E8);
Device_Serial1 = *(__IO uint32_t*)(0x1FFFF7EC);
Device_Serial2 = *(__IO uint32_t*)(0x1FFFF7F0);
Device_Serial0 += Device_Serial2;
if (Device_Serial0 != 0)
IntToUnicode (Device_Serial0, &DFU_StringSerial[2] , 8);
IntToUnicode (Device_Serial1, &DFU_StringSerial[18], 4);
* Function Name : HexToChar.
* Description : Convert Hex 32Bits value into char.
* Input : None.
* Output : None.
* Return : None.
static void IntToUnicode (uint32_t value , uint8_t *pbuf , uint8_t len)
uint8_t idx = 0;
for( idx = 0 ; idx < len ; idx ++)
if( ((value >> 28)) < 0xA )
pbuf[ 2* idx] = (value >> 28) + '0';
else
pbuf[2* idx] = (value >> 28) + 'A' - 10;
value = value << 4;
pbuf[ 2* idx + 1] = 0;
STM32 DFU Serial Unique
2019-01-16 12:51 PM
I doubt this is unique enough.
2019-01-16 12:53 PM
Maybe ST would like to comment on why this implementation was chosen and what sort of uniqueness guarantees it does make.
