Custom Bootloader
contact239955_stm1_st
Posted on March 23, 2012 at 17:54
Hi everybody!
I'm trying to make a bootloader that fetch a program from an SD card. I finally manage to parse the HEX file correctly and write the content in the flash memory but when I try to jump to the program, a Hard Fault is generated and I don't know wh
y.
There's my Flash related code :
FLASH_Unlock();
FLASH_ErasePage(ApplicationAddress + (n-1) * PAGE_SIZE);
FLASH_PageWrite(ApplicationAddress + (n-1) * PAGE_SIZE, page32);
uint32_t startAddress = *(__IO uint32_t*)(ApplicationAddress + 4);
pFunction Start = (pFunction)startAddress;
__set_MSP(*(__IO uint32_t*)ApplicationAddress);
Start();
Where 'n'
is the page number to be written, page32 a pointer to the page content in RAM and 'FLASH_PageWrite()' a custom function to write an entire page by successive calls to 'FLASH_ProgramWord()'
ApplicationAddress = 0x800F000 (My bootloader uses pages up to 0x800A800) Thanks #iap #bootloader #flash
36 REPLIES 36
Posted on March 25, 2012 at 10:38
I change the offset of the vector table to 0xF000 which is the starting address of the application but maybe I'm wrong.
I give you the first lines of my HEX file :
:020000040800F2
:10F0000000C00020052B0108D1F20008DDF2000845
:10F01000E5F20008EDF20008F5F20008000000003B
:10F020000000000000000000000000004D2B01085F
:10F03000FDF20008000000004D2B01084D2B0108D7
:10F040004D2B01084D2B01084D2B01084D2B0108BC
:10F050004D2B01084D2B01084D2B01084D2B0108AC
and this is what I have in the flash memory :
0xF000 : 0xF000 <Hex>
  Address   0 - 3     4 - 7     8 - B     C - F
  0000F000  00C00020  052B0108  D1F20008  DDF20008
  0000F010  E5F20008  EDF20008  F5F20008  00000000
  0000F020  00000000  00000000  00000000  4D2B0108
  0000F030  FDF20008  00000000  4D2B0108  4D2B0108
  0000F040  4D2B0108  4D2B0108  4D2B0108  4D2B0108
  0000F050  4D2B0108  4D2B0108  4D2B0108  4D2B0108
  0000F060  4D2B0108  4D2B0108  4D2B0108  4D2B0108
  0000F070  4D2B0108  4D2B0108  4D2B0108  4D2B0108
  0000F080  4D2B0108  4D2B0108  4D2B0108  4D2B0108
I checked the last bytes too and all is okay.
I don't know the assembly but I give you the first instructions that should be executed if it can helps :
0800f000:   stmia r0!, {}
0800f002:   movs r0, #0
0800f004:   cmp r3, #5
0800f006:   lsrs r1, r0, #32
0800f008:    ; <UNDEFINED> instruction: 0xf2d10800
0800f00c:    ; <UNDEFINED> instruction: 0xf2dd0800
0800f010:    ; <UNDEFINED> instruction: 0xf2e50800
0800f014:    ; <UNDEFINED> instruction: 0xf2ed0800
0800f018:    ; <UNDEFINED> instruction: 0xf2f50800
0800f01c:   movs r0, r0
0800f01e:   movs r0, r0
0800f020:   movs r0, r0
0800f022:   movs r0, r0
0800f024:   movs r0, r0
0800f026:   movs r0, r0
0800f028:   movs r0, r0
0800f02a:   movs r0, r0
0800f02c:   cmp r3, #77     ; 0x4d
0800f02e:   lsrs r1, r0, #32
when the program jumps, it arrives at 0x0800F004 and when I execute the instruction -> Hard fault
Posted on March 25, 2012 at 17:05
Problem solved!
There was a mistake with the MSP loaded value. Now it works fine.
I comment my code and then I publish it, it can be useful to someone else.
Many thanks for your help!
Posted on March 25, 2012 at 18:48
As I said, this is the source and the HEX file of the bootloader (compiled for STM32F103VC). Check main.c for some notes about the bootloader
Hope you'll enjoy it
http://www.mediafire.com/?2748w3w5kraifsv
duongcam1312
Posted on August 09, 2012 at 13:09
clive1
Please tell me why? when I  use FLASH_Unlock(); ...........FLASH_Lock(); in Program IAP at address 0x8005000, After I so use it at Program 0x8000000 but not work?
Posted on August 09, 2012 at 13:54
I'm not sure I understand the question. Could you start a new thread and paste in some example code that explains it more clearly.
duongcam1312
Posted on August 09, 2012 at 18:27
I use resource AN2557 of ST to Update firmware by FTP Server.
In Bootloader i use algorithm :
check Flash address 8004000 ---->
check =*((uint8_t *) Address);
if ( check==0xFF)
//connect FTP;
//Down firmware
FLASH_Unlock();
//Wrtite to 0x8005000;
//Write 0x11 to 0x8004000;
FLASH_Lock();
// offset run program application
JumpAddress = *(__IO uint32_t*) (StartAddr + 4);
Jump_To_Application = (pFunction) JumpAddress;
NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x5000);
__set_MSP(*(__IO uint32_t*) StartAddr);
Jump_To_Application();
else
In Program Application i use algorithm :
if need update new firmware
Addess=0x8004000;
FLASH_Unlock();
FLASH_ClearFlag(FLASH_FLAG_BSY | FLASH_FLAG_EOP | FLASH_FLAG_PGERR | FLASH_FLAG_WRPRTERR);
FLASH_ErasePage(Addess);
FLASH_Lock();
NVIC_SystemReset();
First run : OK Second run : Can not Erase Old firmware in address 0x8005000 to write new firmware
Can you tell me why please?
Thank you verry much.
Posted on August 09, 2012 at 18:47
Ok, a couple of additional questions.
What part are you using, and what is the flash page size?
Where is the code erasing 0x08004000 situated, ie execution address?
What status does FLASH_ErasePage(0x08004000) return?
What does the page at 0x08004000 look like post erase?
What does the erase code for 0x08005000 .. 0x080XXXXX look like?
duongcam1312
Posted on August 10, 2012 at 04:50
I work with STM32f103VCT6. Flash Page size 2K.
first run,because i load chip by
Flash Loader Demo
, so that erase all page flash second run, I erasing:
FLASH_Unlock();
StartAddr=0x8005000;
EndAddr =0x800C000;
/* Define the number of page to be erased */
NbrOfPage = (EndAddr - StartAddr) / FLASH_PAGE_SIZE;
/* Clear All pending flags */
/* Erase the FLASH pages */
for(EraseCounter = 0; (EraseCounter < NbrOfPage) && (FLASHStatus == FLASH_COMPLETE); EraseCounter++)
FLASHStatus = FLASH_ErasePage(StartAddr + (FLASH_PAGE_SIZE * EraseCounter));
In program application i erase page 0x8004000 -> 0x80047FF . OK
hereproblem : If adrress 0x8005000-->0x8 X ==0xFF, i write into flash OK.But it have program, can not write or erase
respect
Posted on August 10, 2012 at 05:39
FLASH_Unlock();
EndAddr =0x800C000;
NbrOfPage = (EndAddr - StartAddr) / FLASH_PAGE_SIZE; /* watch boundaries, integer count */
for(EraseCounter=0; EraseCounter<NbrOfPage; EraseCounter++)
if (FLASHStatus != FLASH_COMPLETE)
break;
duongcam1312
Posted on August 10, 2012 at 06:51
Thanks clive1 ! I worked ok
Thank you verry much.Have a nice day!
