Connect to target fails with "Failed to execute MI command:"
‎2021-09-27 8:33 AM
Error in final launch sequence:
target remote localhost:61234
Error message from debugger back end:
localhost:61234: Das System hat versucht, einem Verzeichnis, das sich auf einem mit JOIN zugeordneten Laufwerk befindet, ein Laufwerk mit SUBST zuzuordnen.
‎2021-09-27 9:06 AM
Hello @FLueb​
your error message is strange. It seems to show you are not using local drive.
I've never heard about this JOIN.
Do you have a specific setup ?
Best regards
Jocelyn
‎2021-09-27 9:08 AM
The Workspace and all related content ist on a local drive.
Path is quite simple:
C:\Azure-RTOS-WS\workspace
‎2021-09-27 9:23 AM
Hello @FLueb​
OK thank you for your feedback.
I still have no idea what is going on.
Could you try
1) Start from scratch with new workspace (you can just erase this one which is fine for location) and do each step again.
2) If issue is still there, try to change in the debugger configuration (Run/Debug configuration) in tab Debugger, the debug probe from ST-Link (ST-Link GDB server) to ST_link (Open OCD).
Also, try using another USB cable. I don't think this is the issue but just in case...
Best regards
Jocelyn
‎2021-09-27 11:59 PM
ST_link (Open OCD) has same problem
‎2021-09-28 12:09 AM
Probleme solved. Was related to usb-hub
‎2021-09-28 12:11 AM
Hi @FLueb​
Great that you solved this issue.
That is one important information !
Thank you for your feedback.
Best regards
Jocelyn
