Changing a PWM complementary pins to GPIO functionality and then back to PWM at runtime
Ricko
Senior III
I am running TMR1 CH1 and CH1N in complementary mode (so they are the opposite of each other).
Using a HAL function, how do I change each (separately) from PWM to GPIO and back to PWM?
Just so to explain what I am trying to do... I am driving a H-bridge, I want to be able to:
- run the PWM in complementary mode (i.e. biphase/bipolar bridge)
- fix one half of the bridge to high or low while the other side still runs in PWM
- switch both to either high or low
- go back to full PWM complementary
Thank you
10 REPLIES 10
Thank you @TDK
