[BUG] DAC software trigger at STM32L431 have not set DAC_SWTRIGR_SWTRIGx Bit.
2024-09-20 8:38 PM
My last page is: Re: Why DAC output nothing in software trigger? - STMicroelectronics Community
I have find CubeMX BUG.
I use STM32L431RCT6 and software version is STM32CubeL4 Firmware Package V1.18.0 / 07-June-2023
My STM32CubeMX config is:
And my code in main() is:
HAL_DAC_SetValue(&hdac1, DAC_CHANNEL_2, DAC_ALIGN_12B_R, 4095);
HAL_DAC_Start(&hdac1, DAC_CHANNEL_2);
But the PA5 have no voltage.
I find the "stm32l4xx_hal_dac.c" file HAL_DAC_Start() function is:
HAL_StatusTypeDef HAL_DAC_Start(DAC_HandleTypeDef *hdac, uint32_t Channel)
/* Check the parameters */
assert_param(IS_DAC_CHANNEL(Channel));
/* Process locked */
__HAL_LOCK(hdac);
/* Change DAC state */
hdac->State = HAL_DAC_STATE_BUSY;
/* Enable the Peripheral */
__HAL_DAC_ENABLE(hdac, Channel);
#if defined (STM32L4P5xx) || defined (STM32L4Q5xx) || defined (STM32L4R5xx) || defined (STM32L4R7xx) || defined (STM32L4R9xx) || defined (STM32L4S5xx) || defined (STM32L4S7xx) || defined(STM32L4S9xx)
if (Channel == DAC_CHANNEL_1)
/* Check if software trigger enabled */
if ((hdac->Instance->CR & (DAC_CR_TEN1 | DAC_CR_TSEL1)) == DAC_TRIGGER_SOFTWARE)
/* Enable the selected DAC software conversion */
SET_BIT(hdac->Instance->SWTRIGR, DAC_SWTRIGR_SWTRIG1);
else
if ((hdac->Instance->CR & (DAC_CR_TEN2 | DAC_CR_TSEL2)) == (DAC_TRIGGER_SOFTWARE << (Channel & 0x10UL)))
/* Enable the selected DAC software conversion*/
SET_BIT(hdac->Instance->SWTRIGR, DAC_SWTRIGR_SWTRIG2);
#endif /* STM32L4P5xx STM32L4Q5xx STM32L4R5xx STM32L4R7xx STM32L4R9xx STM32L4S5xx STM32L4S7xx STM32L4S9xx */
#if defined (STM32L431xx) || defined (STM32L432xx) || defined (STM32L433xx) || defined (STM32L442xx) || defined (STM32L443xx) || \
defined (STM32L471xx) || defined (STM32L475xx) || defined (STM32L476xx) || defined (STM32L485xx) || defined (STM32L486xx) || defined (STM32L496xx) || defined (STM32L4A6xx)
if(Channel == DAC_CHANNEL_1)
if ((hdac->Instance->CR & (DAC_CR_TEN1 | DAC_CR_TSEL1)) == DAC_CR_TEN1)
else
if ((hdac->Instance->CR & (DAC_CR_TEN2 | DAC_CR_TSEL2)) == DAC_CR_TEN2)
#endif /* STM32L431xx STM32L432xx STM32L433xx STM32L442xx STM32L443xx */
/* STM32L471xx STM32L475xx STM32L476xx STM32L485xx STM32L486xx STM32L496xx STM32L4A6xx */
#if defined (STM32L451xx) || defined (STM32L452xx) || defined (STM32L462xx)
if((hdac->Instance->CR & (DAC_CR_TEN1 | DAC_CR_TSEL1)) == (DAC_CR_TEN1 | DAC_CR_TSEL1))
#endif /* STM32L451xx STM32L452xx STM32L462xx */
hdac->State = HAL_DAC_STATE_READY;
/* Process unlocked */
__HAL_UNLOCK(hdac);
/* Return function status */
return HAL_OK;
But in rm0394-stm32l41xxx42xxx43xxx44xxx45xxx46xxx-advanced-armbased-32bit-mcus-stmicroelectronics.pdf the TSELx config 0b111 with SWTRIG:
SO the code in check if software trigger enabled have error:
else
Need change with:
if ((hdac->Instance->CR & (DAC_CR_TEN1 | DAC_CR_TSEL1)) == (DAC_CR_TEN1 | DAC_CR_TSEL1)) {
else
if ((hdac->Instance->CR & (DAC_CR_TEN2 | DAC_CR_TSEL2)) == (DAC_CR_TEN2 | DAC_CR_TSEL2)) {
So the PA5 have voltage.
I only test STM32L431RCT6.
- Labels:
DAC
STM32L4 series
2024-09-23 3:31 AM
Hi @Wshuo.1 ,
Thank you and @waclawek.jan for bringing this issue to our attention.
I reported it internally to be fixed by our development team.
Internal ticket number: 191791 (This is an internal tracking number and is not accessible or usable by customers).
-Amel
