Are HAL_ppp_MspInit functions the only place to initialize low level resources?
chenlijun1999
Hi everybody.
I'm met several scenarios in which the use of HAL_PPP_MspInit
would be too constraining.
A typical example is when I'm making a reusable library that needs
some peripheral. If I initialize the low level resources for the peripherals
used by the library in HAL_PPP_MspInit functions, then the application code
won't be able to use them anymore.
I've always initialized the low level resource before calling HAL_PP_Init and
it has always worked. But I would like to have your confirm that I'm doing is legitimated.
Yes is it reasonable and legitimate to do clock and pin initialization elsewhere prior to usage.
chenlijun1999
Thank you very much for the answer!
