About RTOS and Java
vincent.philippe
Posted on May 07, 2013 at 16:23
Hi
Question about the RTOS:
What kind of RTOS is used?
Are there constraints?
What is the availablility?
Is there a need to use Linux?&&sharp31;
#rtos-+-java
vincent.philippe
Posted on May 13, 2013 at 10:48
Hi
 We use Keil RTXOS. There are no particular constraint, the Java application runs in one thread. If need, your application can use other thread for specific drivers.
You don't need to use Linux.
Rgds
Phil
SeaFood
Posted on May 28, 2013 at 12:10
Any RTOS offer will make the job. It can be µC/OS, FreeRTOS, ThreadX, ...
