This is a specific question Programming a new IC STM32030 using an ST-Link and STM32CubeProgrammer. I have spent considerable time trying to understand why I cannot connect to my stm32.
I have attempted to connect and program through STM32CubeIDE also.
‎2020-02-26 9:48 PM
The St_link registers itself and the serial is updated etc. however when I attempt to connect to the newly soldered chip, I get the message that "No STM32 target found".
Am I attempting to program this chip incorrectly by using the SWDIO, GND, SWCLK and 3.3v single wire connections.
There is little to no examples I have found to do this, as most examples are for the premade nucleo boards etc.
Any advice would be greatly appriceated, or a reference to the correct data.
- Labels:
ST-Link
STM32CubeIDE
STM32CubeProgrammer
‎2020-02-27 1:23 AM
At least GND and 3.3V appears to be working, because ST-Link is able to detect it.
Have you tried other settings, like connect under reset, or lower frequency?
‎2020-02-27 1:47 PM
I haven’t tried different frequencies, I can give that a try.
As for doing it under reset. Would that be done through grounding the reset pin?
‎2020-02-27 1:56 PM
Yes, the flashing or debugging session will be started with reset pulled low. Of course you have to connect it to the ST-Link for it to work. Useful if the software messes up GPIO configuration (intentionally or by mistake). Though it should not be necessary with a brand new chip.
