STM32CubeProgrammer & ST-LINK/V2 & STM32F030
I get "Error: No STM32 target found!" error regardless of what configuration I try.
‎2020-12-16 1:49 AM
Log:
ST-LINK SN : 55FF6F066675544945212587
ST-LINK FW : V2J37S7
Board : --
Voltage : 3.99V
The soldering is done correctly (tried it on multiple boards as well).
The correct USB driver is being used.
Not sure if relevant, but will add the following info:
> ARM-JTAG 20-10 adapter
> Under "ST-LINK/V2" it's written "B 2020 26"
What could be wrong? What should I try?
Edit:
The voltmeter reads 3.3V. (The earlier "Voltage : 3.99V" is from the logging output of STM32CubeProgrammer)
Edit 2:
So my PCB is connected to a battery source that supplies 3.3V when the switch is on (without ST-LINK/V2)
When the switch is off, the log outputs from STM32Cube Programmer reads 0.7V.
So I reckon, the combination of being connected with a battery source and the ST-LINK/V2 creates 4V that I was getting earlier.
Is this a thing? How do I resolve this? Do I need to provide an adjusted power source every time I update the software?
ST-Link
STM32CubeProgrammer
STM32F0 Series
‎2020-12-16 4:54 PM
Hello.
> Voltage : 3.99V.... Too high. Is this the VDD voltage from MCU?
‎2020-12-16 5:41 PM
Tends to happen if the chip is non-functional or not connected properly.
4V probably not good, you'll want to double check that.
‎2020-12-16 5:48 PM
Oh, I missed "VDD = 2.4 V to 3.6 V​" in the documentation. Thank you. I'll check this and update if it fixed the issue or not.
‎2020-12-16 6:05 PM
Updated original post.
‎2020-12-16 6:05 PM
‎2020-12-18 10:07 AM
GND, SWDIO, SWCLK must be connected to board at least.
‎2020-12-18 10:43 AM
Common the grounds in the system.
