STM32(f303cbt) chip never reaches while loop in default cubeMX generated code.
falseReality
I designed my own PCB and created a project with STM32CubeMX for Truestudio with the chip taht I used on my board (stm32f303cbt). This is the first time I made my own PCB and my last project was done with an AVR chipset.
When I debug the chip with the code generated by cubeMX, it never reaches the while loop.
The main function looks like this:
int main(void)
  HAL_Init();
  SystemClock_Config();
  int i = 0;
  while (1)
	  i++;
	  if(i>100) {
		  i=0;
After executing the `SystemClock_Config();` function, I can't pause or step through the code anymore with the debugger. I can step into the SystemClock_Config(); function, but after the last line it looks like the chip is busy with this line until the end of time.
I might be missing crucial info since I don't know where I should be looking to solve this error. Here are some extra screenshots of the cubeMX configuration.
3 REPLIES 3
So perhaps show the code that's actually failing and not the level above it.
Flash wait states? Clocks or PLL not starting? Errors returned, helpful infinite loops? ​
falseReality
Here is a video of what happens when I debug and try to step towards the while loop:
https://www.youtube.com/watch?v=YUmL_YaZdeo
Here is a copy of the SystemClock_Config(); as well:
  * @brief System Clock Configuration
  * @retval None
void SystemClock_Config(void)
  /**Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSI;
  RCC_OscInitStruct.PLL.PLLState = RCC_PLL_NONE;
    Error_Handler();
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSI;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
Something I noticed is that the Error_Handler functions are never called. Neither do I find any errors that are linked to this problem in the console.
falseReality
I don't know how to read/change these values and states. Aren't the default values ok for normal operations?
