2015-03-02 05:17 AM
i'm trying to load an .hex file into an ARMSTM32F103R6 with St-link/V2
but there is something that doesn't work (see attached img). Could you help me pls? #st-link/v2-programming-issue2015-03-02 08:25 AM
Says the erase failed. Guess I'd look at the board for issues, either design or construction. No real detail provided.
Does a bulk/mass erase work independently of the download?2015-03-02 08:37 AM
2015-03-02 08:54 AM
If the ST-LINK has current firmware, and it's not a SWD/JTAG issue, or one of the other connection options, you'll need to find someone at ST to discuss the issue with you.
2015-03-03 02:03 AM
OK, I'll contact ST.
thanks a lot.
