Schematic check
‎2023-02-20 12:45 PM
I'm learning how to make a PCB with an STM32H725IGK6 MCU (UFBGA), which will be used as a flight controller for a drone. This is the first proper attempt I've done at creating a schematic, so I would appreciate it if someone more experienced would be able to look over it and give any feedback or spot any obvious electrical errors.
Thanks for your time.
- Labels:
STM32H7 series
‎2023-02-20 5:38 PM
- Put a 100 nF capacitor from NRST to GND.
- I see +BATT line at U3, but at no other part.
- Not sure about the necessity of D6.
- For a simple power sinking device USB-C requires two 5,1k pull-down resistors on CC1/CC2 lines.
- The LDO/SMPS related connections and VCAP capacitors seem to be wrong. Read the AN5419.
‎2023-03-05 4:08 PM
thanks for the response.
im struggling to understand what the datasheet is saying about the LDO/SMPS connections, and which combination i should use. ive replaced the 5v to 3v3 linear regulator with an SMPS instead (to reduce power loss). i am guessing that i should use External SMPS supply, supplies LDO, but even if this is correct the diagram confuses me and i dont really understand what it means. would you be able to point me in the right direction?
