2026-02-01 9:40 AM - last edited on 2026-02-02 8:54 AM by Andrew Neil
I am trying to make a basic Enhanced Advertising low power application using Arduino IDE.
I use a standard P-NUCLEO WB55.
I need Arduino IDE because this application is intended to be open for modifications.
The current STM Documentation (https://wiki.st.com/stm32mcu/wiki/Connectivity:STM32WB_BLE_Arduino) is more than one year old and is outdated.
I succeed in lighting the 3 color led by redefining their PIN OUT according with the electrical schematic. But I was not even able to get print messages (I guess the Serial is not properly define for that board).
Where can I found a basic Arduino Example.
I did already the update of the M0 FW which is supposed to be HCI compliant. FUS version V2.2.0.0 and STACK version v1.24.0.3.
Thanks in advance.
Edited to fix link.
2026-02-03 9:43 AM
If that's answered your question, please mark the solution.
Please give a link to you thread on the stm32duino forum - so that anyone who finds this can follow it...
2026-02-02 8:39 AM
Welcome to the forum.
This forum is focussed on "conventional" development, using things like Keil, STM32CubeIDE, etc.
For Arduino questions, you'd be better at:
Or the main Arduino forums:
@fbd38 wrote:I need Arduino IDE because this application is intended to be open for modifications
That doesn't follow at all!
It's perfectly possible to modify applications built using other IDEs.
2026-02-03 9:03 AM
Thanks a lot. I will continue on the stm32duino forum.
By the way I tried the CubeMX IDE, which is very nice, but the "entrance ticket" is too high for non-professionals.
2026-02-03 9:43 AM
