vbk22398
April 30, 2025
RED LED On due to unknown reason!
  • April 30, 2025
  • 7 replies
  • 889 views
I am using STM32F767ZI board for my projects. But due to some unknown reason, the RED led is turned ON in my nucleo board. I am sharing my code along. The code is very simple and I enabled only a single GPIO to be output. Please let me know my mistake! Where am I going wrong. What is my issue.! Also i haven't enable any GPIO that concerns RED Led. Please let me know the answer!
Thanks!
Andrew Neil
Do you mean the NUCLEO-F767ZI ?
https://www.st.com/en/evaluation-tools/nucleo-f767zi.html
You mean LD3 ?
Have you tried stepping through your code in the debugger to see exactly when it comes on?
PS:
You can download the schematics from the 'CAD Resources' Tab on the board's Product Page:
https://www.st.com/en/evaluation-tools/nucleo-f767zi.html#cad-resources
LCE
Principal II
April 30, 2025
Which LED do you mean?
Several LEDs on the Nucleo, and some connected to the on-board ST-Link, some at the power supplies...
Andrew Neil
Indeed.
@vbk22398 here's the full list:
So there's four LEDs which could possibly show red ...
vbk22398
vbk22398Author
April 30, 2025
LD3.
vbk22398
vbk22398Author
April 30, 2025
@Andrew Neil I tried to enter into debug mode but it doesn't start from main, it starts outside main and if i go inside the function, then it opening a function inside the main, whilst the debug is still outside in some random line.!
Tesla DeLorean
Guru
April 30, 2025
Like it ended up in Error_Handler?
Or it's just running some completely different code? Double check build completes and you download correctly.
Perhaps mass erase and confirm LED goes off.
