Nucleo L010RB USART working only if you plug the USB
‎2023-08-02 1:50 AM
I'm working on a nucleo L010RB board, i wanted to test my application on battery supply but the USART2 didn't work without the usb ST-LINK so i assumed that the USART3 would work but it's the same problem.
When I start the nucleo with only battery the nucleo seems to start up right (I am making the user led blinking in the program loop.) but I don't receive any prompt on my uart and as soon I plug the usb I start getting all messages.
I am assuming that there is something with ST-LINK waiting to be link with a computer.
PS: I correctly put the JP5 on E5V.
Thanks for the help.
J
STM32L0 Series
‎2023-08-02 3:10 AM - edited ‎2023-08-02 3:12 AM
Hello
You dont give very much info about your connections, but maybe your ground is missing from mcu to pc (some usb/uart adapter ?). And when you hook up stlink, grounds connect that way.
Or how you receive the uart communication ?
Br J.T
Hello
Br J.T
‎2023-08-02 5:17 AM
Thanks,
Your guess was right. I had to plug the ground to my usb/uart adapter.
