2021-09-29 6:17 AM
Is it possible for debugging for external application? My intension is to use STM Nucleo board CN4 to debug instead of one extra STLINK V2 or V3. Is it possible ?
Pin connections will be as follows.
2021-10-01 12:28 AM
Crystal: one with 8MHz is not necessarily the same as another with 8MHz. You should definitely read the above-mentioned AN2867 so that you understand the background and how to use crystals.
/Peter
