I have bought new stm32l562E-DK board recently, I have written embedded rust code to blink an led. the compilation is proper binary file generated. When I Flash it is showing this error. Please help me out.
bsara.1
sarathk@sarath:~/Desktop/project/open_s_projects/rust_projects/stm32l/led_blink$ probe-run target/thumbv7em-none-eabihf/debug/led_blink --chip stm32l562qeixq
Error: Error while flashing
Caused by:
   0: Something during the interaction with the core went wrong
   1: An error with the usage of the probe occured
   2: Operation timed out
13 REPLIES 13
I have connected under reset, it is showing the same issue.
Yes this first time programming the board.
That is I am not sure. When I press reset button LD4, LD5,LD6 and LD7 glows in sequence and stops. Finally the LD9, LD10 and LD5 are on.
Hi, still I am not able to figure out the issue , Can you please help me. Thank you.
Hi @bsara.1​ ,
Try the tips provided in the article How to solve debugger connection issues?
May be you altered debug pins with your first loaded code.
-Amel
Piranha
Chief II
Mode: Under reset
Reset mode: Hardware reset
