How to skip the interruption while debugging STM32F746-Discovery with Cube-IDE ?
MOUAN
I am using the ST-LINK GDB server as a debugger under Cube-IDE , in every step over the debugger enter to interrupt and never go out, is there any solution to skip the interruption.
E.g. In my application the interruption that occur is :
void TIM6_DAC_IRQHandler(void)
 /* USER CODE BEGIN TIM6_DAC_IRQn 0 */
 /* USER CODE END TIM6_DAC_IRQn 0 */
 HAL_TIM_IRQHandler(&htim6);
 /* USER CODE BEGIN TIM6_DAC_IRQn 1 */
 /* USER CODE END TIM6_DAC_IRQn 1 */
I tried to Debug the application with OpenOCD but Cube-IDE didn't let me configure it .
Any Ideas ?
1 REPLY 1
KnarfB
Principal III
Its a limitation in the chip. A workaround is: put the following two lines into main():
 DBGMCU->APB1FZ = 0xFFFFFFFF;
 DBGMCU->APB2FZ = 0xFFFFFFFF;
This does not stop everyting, but helps.
Frank
