How to interface or use STM32H563ZIT6 USB Host
‎2024-09-13 4:10 AM - last edited on ‎2024-09-13 7:15 AM by Mike_ST
Hi, I tried to configure the USB Host for a project, but it’s difficult to configure, and I am not finding any online support available for the STM32H5 series controller.
My requirement: I configured PB4 as an output, which is connected to a green LED. Whenever I plug the USB into my controller, the green light turns on, and whenever I remove the USB from the controller, the green light turns off.
I’ve tried some methods, but they are not working. Can anyone please help me?
STM32H5 Series
‎2024-09-25 7:27 AM
>> it is applicable for Customized board STM32H563ZIT6 Controller?
No.
As per STM32H563 reference manual , there is a "Universal serial bus full-speed host/device interface"
So, host mode is supported on that chip, if you've made a design of your own, it should work.
‎2024-09-13 4:14 AM
sorry i Mis-understandingly mention the labels as STM32G0 Series.but The original Label is STM32H5
‎2024-09-13 8:09 AM
you can find an USB HOST example for STM32H5 in the Projects\STM32H573I-DK\Applications\USBX\Ux_Host_HID_CDC_ACM folder of the software package availbable here:
Your project seems to make use of an old package v1.1.1 when v1.3.0 is available.
Just in case you're using a Nucleo 144 with STM32H563ZIT6, host mode is not supported on that board.
‎2024-09-24 6:09 AM
‎2024-09-25 7:27 AM
No.
‎2025-04-07 7:04 PM
Why is host mode not supported on the STM32H563ZIT6 nucleo if it is supported by the chip?
I've been trying to implement USB Host on a custom board with the STM32H563RGT6 with several example projects from ST with the ST USB_Host and FATFS middleware provided. In every case I just constant USB interrupts that blocks all other operation.
