2023-01-01 12:14 AM
Hey,
I built a project base on the STM32 G070RB Nucleo board.
Now i want to take the cpu and design my own board for a project in my work.
My question is how to connect the STlink v2 to the CPU, because i saw in 3 diffrent resources, diffrent numbers of legs to connect.
2.Datasheet of the board(5 Legs, number 6 is not used!)
3.Datasheet of the STlink V2(20 Legs)
Can any one tell me what is the corrent way ?
2023-01-01 12:49 AM
App. note "Getting started with STM32G0 Series hardware development" is a recommended reading.
GND, SWDIO, SWCLK are mandatory.
NRST optional if you want to reset the board for debugging
VDD_TARGET/Target VCC optional for detecting/measuring the board voltage/level conversion by the debug probe
SWO additional serial output for logging/tracing, not implemented in G0 series.
hth
KnarfB
2023-01-01 12:49 AM
hth
KnarfB
2023-01-02 12:50 AM
Thank you for your reply!
where can i find "Getting started with STM32G0 Series hardware development" ?
2023-01-02 01:01 AM
You can find it on the product page on ST website, under the tab 'Documentation'.
https://www.st.com/en/microcontrollers-microprocessors/stm32g0-series.html#documentation
But here's a direct link:
2023-01-02 09:36 AM
