Hi, I am using stm32f042g6u6 in my design, Also i am using Keil uVision5 ide, Debugger : stlink v2 The problem is debug is not working in my circuit, controller is detected successfully, i cant figure out the reason exactly, need your inputs .
Ss.61
4 REPLIES 4
KnarfB
There is a Getting started with STM32F0x1/x2/x8 hardware development with ref. schematics. How does your desing look like?
hth
KnarfB
gbm
Principal
Also, make sure that the SW clock frequency set in Debug settings is 1..2 MHz (The default value may be too high).
My STM32 stuff on github - compact USB device stack and more: https://github.com/gbm-ii/gbmUSBdevice
like schematic everthing is same still facing same issue.
Ss.61
This is our second version first version is working fine ,
In new one we are facing issue.
