Apr 2, 2025 7:58 AM UTC
Debugging STM32F413xx with SWD using SWO.
Please help me.
I'm a beginner to designing stm32 hardware designs. I need to program my STM32F413VGT3 microcontroller using SWD(Serial wire debugger). Also I need to use SWO option. I designed a circuit for this.
1. I want to know about can I use SWO with SWD interface?
2. Is my circuit(attached) is correct? (I'm not sure that 50ohm resistors and 100K pullup resistor)
Andrew Neil
Apr 2, 2025 8:12 AM UTC
Are you familiar with any other microcontroller(s)? In particular, ARM Cortex-M microcontrollers?
The best starting point is to get the manufacturer's development/evaluation/demo board(s), and use that to gain familiarity.
Then you can base your own design on that board.
To find development boards for any ST part, got to the Product Page and look on the 'Tools & Software' tab:
https://www.st.com/en/microcontrollers-microprocessors/stm32f413vg.html#tools-software
You will see that there's a NUCLEO-F413ZH and a 32F413HDISCOVERY:
https://www.st.com/en/evaluation-tools/nucleo-f413zh.html#documentation
https://www.st.com/en/evaluation-tools/32f413hdiscovery.html#documentation
They both have SWO
Also, see Application Note AN4488, Getting started with STM32F4xxxx MCU hardware development:
https://www.st.com/resource/en/application_note/an4488-getting-started-with-stm32f4xxxx-mcu-hardware-development-stmicroelectronics.pdf
via: https://www.st.com/en/microcontrollers-microprocessors/stm32f413vg.html#documentation
Apr 2, 2025 8:20 AM UTC
Yes I familiar with development boards. I checked my project using a Discovery board. But now i need a build a custom circuit.
I designed this circuit using the Application notes, data sheets. Now I need to verify that is my wirings are correct?
Also I want to know about can I use SWO with SWD interface?
Thank you.
Andrew Neil
Apr 2, 2025 8:28 AM UTC
You could answer that by trying it on the Disco board ...
