2024-02-19 8:06 PM
Hi there,
Just wondering if there are any 3.5" - 5" displays that are compatible with the Nucleo-H755ZI-Q. I require a standalone screen that is not attached to a development board. I am currently using the below screen:
https://www.dfrobot.com/product-2107.html
Any information would help.
Thank you, Isaac
2024-02-19 8:15 PM
That particular display communicates over SPI and is compatible with the Nucleo-H755ZI-Q. Most displays are going to be compatible with the STM32H7.
2024-02-19 8:15 PM
2024-02-19 8:42 PM
Great! Do you know of any alternative displays around the 3.5" - 5" dimensions that would recommend? Looking for a slightly higher quality.
2024-02-19 8:49 PM
Hmm, not really. The display on STM32H747I-DISCO is nice if you wanted to track down that part number.
https://www.st.com/en/evaluation-tools/stm32h747i-disco.html
I would suggest doing a parametric search on digikey or other reputable supplier and you're bound to get a lot of hits. Sorting by most in stock generally tells you what is popular. Searching google for libraries on those can also help you get a sense of what is popular.
