st25r3916b full power antenna
SG3
I am using the st25r3916b to read cards (ISO14443A) and as card emulator. I am not sure if I am using the maximum antenna power. If you could give the clue of which registers and which values should I use to have it with the maximum output power.
Thanks,
Sandra
Ulysses HERNIOSUS
Hi Sandra,
maximum output power is mainly a function of:
  1. Antenna and matching impedance
  2. Driver resistance setting (d_res) - make sure it is at lowest value (lowest resistance)
  3. Power supply / regulator settings / regulator bypass. Depends on your supply voltage and stability what you can/want to use. From software perspective reg_s/rege settings.
Best Regards, Ulysses
Ulysses HERNIOSUS
Hi Sandra,
Perfect, thank you!
