st25r3916 Firmware migration
SG3
Hi all,
I would like to migrate your example code from st25r3916 disco demo board to my own microcontroller to use it as a card emulator. I have downloaded the "STSW-ST25R011" firmware.
I already tried by myself, removing many code but i had no sucess. I plan to start again from scratch, so any hint will be high appreciatted
Ulysses HERNIOSUS
Hi SG3,
I would rather recommend using a nucleo setup: X-NUCLEO-NFC06/08 with NUCLEO-L476. With this you can directly use the pairing demo from ST25 NFC Lib (STSW-ST25R-LIB / STSW-ST25R016).
Of course you can also try to use the pairing demo on your disco board setup but some porting will be needed as the pinout is not the same.
BR, Ulysses
2 REPLIES 2
Ulysses HERNIOSUS
Hi SG3,
BR, Ulysses
Thank you!
