2019-10-01 11:04 AM
ST25R3916 Datasheet DS12484 Rev 1 Typo/Errors:
ST25R3916 Datasheet missing details/chapters about how to use the registers:
It will be very good to have some chapter to guide users/developers how to configure the different chipset common mode like:
Note: I have developped a sigrok / PulseView plugin for ST25R3916 which will be released as Open Source which have helped me a lot to better understand how work the chipset (with the help of ST25R3916 Discovery Board)
2019-12-09 12:01 AM
2019-10-01 11:27 PM
thanks for your input on our DS. What you find on the web is only the first version which does not contain much information of how to use the device. We are currently working on a new version of the DS which I hope to be released soon.
However I have the feeling that it will still not answer all your questions. If you want to use the device without our drivers you will need to study a few things more:
Regards, Ulysses
2019-10-02 10:41 AM
Thank you for your very fast answer
Do you have an estimated release date for new ST25R3916 Datasheet ?
2019-10-02 11:48 PM
I would expect this to happen by end of November.
BR, Ulysses
2019-12-03 11:38 PM
Do you have an update about estimated date for updated Datasheet ?
2019-12-09 12:01 AM
a new DS version is now available.
BR, Ulysses
2019-12-09 09:38 AM
Thanks for the feedback and new DS version
I see there is big improvement in the new datasheet (with lot of things added) and that all Typos / Errors I have reported are fixed
