2020-06-04 11:41 PM
I would like to increase no-response time by a few ms instead of 64/fc (4.72us) or 4096/fc(302.08us?), say 100ms(milliseconds). What should be the values in 0Fh, 10h and 11h registers.? I see bit4 in 0Fh register mentions time configuration in milliseconds configuration but don't how to use.
Host uses rfal API.
Thank you for your support!
Thanks,
Veera
2020-06-05 1:47 AM
the rfalTransceiveBlockingTxRx() and rfalTransceiveBlockingTx() APIs in the RFAL have a fwt parameter (Frame Waiting Time in 1/fc). This will set the No-response timer registers accordingly.
Can you elaborate about your use case (e.g. which technology A/B/F/V/P2P) and explain why you need to increase the non response timer?
Rgds
BT
2020-06-05 1:47 AM
Rgds
BT
2020-06-30 11:37 AM
Sorry I missed your response somehow I did not receive a notification though.
We've an application level security added and ran into some issues at the RF transport. To debug, I want to try to extend the non-response timer to a few milli seconds. We sorted out the issue. Thank you for your support.
Thanks,
Veera
