2024-11-17 01:24 AM
Hi I am developing a NFC reader design based on ST25R3916B chip. PCB design is in progress. Due to mechanical constraints, NFC antenna would not be in this PCB. So can you pls suggest suitable antenna part number with size more than 50mmX50mm and cable connector assembly part number to connect this antenna to reader PCB. I would like to use around 200mm cable length for connecting antenna to reader.
