2021-11-25 05:53 AM
app_twi_perform() returns 0x03 == NRF_ERROR_INTERNAL.
Reset board with button does not help.
After Power Cycle can update EEPROM successfully.
Accessing FTM buffer with proprietary smartphone app.
2021-11-26 02:39 AM
Sorry, it is a little bit difficult to help with so few information...
Nevertheless, I think your problem may be that you try to write into EEPROM with the FTM activated.
As explained in the ST25DV datasheet (https://www.st.com/resource/en/datasheet/st25dv04k.pdf) chapter "5.1.2 Fast transfer mode usage" in the "caution" paragraph of page 25, it is not possible to write into EEPROM if FTM is activated (meaning of bit 0 of MB_CTRL_Dyn register value is 1).
A "power on/off cycle" reset the MB_CTRL_Dyn register, thus deactivating the FTM, which can explain why you can write EEPROM after the ON/OFF cycle. Not sure about the "reset board" since I don't know what board you are talking about.
So, my suggestion is to try to disable FTM before trying to write into EEPROM.
Best regards.
2021-11-26 02:39 AM
Best regards.
2021-11-26 06:07 AM
Thank you, JL.
That indeed was the case. Appreciate your advice and great customer support.
EDIT. Sometimes it still crashes when setting MB_CTRL_Dyn register.
