2021-07-17 1:46 AM
My setup is ST25R3911B / RF-HL ported to ESP32.
Recently came across NDEF middleware in "ST25NFC_Embedded_Lib_ST25R3911B". I'm trying to read T2T NFC-A cards but whenever I try to run the NDEF middleware part, the "ndefPollerNdefDetect" function returns error code 11. ( ERR _PROTO )
Here's the flow of my code:
1) rfalNfcGetActiveDevice(&nfcDevice);
If the active device is a T2T card:
2) ndefPollerContextInitialization(&ndefCtx, pNfcDevice); - No error returned
3) ndefPollerNdefDetect(&ndefCtx, &info); - Returns error code 11 ( ERR_PROTO )
What could be the cause of this?
Best Regards,
Ayush Sharma
2021-07-18 12:25 PM
your T2T tag is probably not NDEF formatted and therefore the ndefPollerNdefDetect fails to find the Capability Container. I suggest to check the content of Block #3 (it should start with E1 10 .. ..). You can use ST25 NFC Tap on an Android phone to check the content of the block #3.
Rgds
BT
2021-07-18 12:25 PM
Rgds
BT
