ndefPollerNdefDetect always returns ERR_PROTO ( 11 )
AShar.10
My setup is ST25R3911B / RF-HL ported to ESP32.
Recently came across NDEF middleware in "ST25NFC_Embedded_Lib_ST25R3911B". I'm trying to read T2T NFC-A cards but whenever I try to run the NDEF middleware part, the "ndefPollerNdefDetect" function returns error code 11. ( ERR _PROTO )
Here's the flow of my code:
1) rfalNfcGetActiveDevice(&nfcDevice);
If the active device is a T2T card:
2) ndefPollerContextInitialization(&ndefCtx, pNfcDevice); - No error returned
3) ndefPollerNdefDetect(&ndefCtx, &info); - Returns error code 11 ( ERR_PROTO )
What could be the cause of this?
Best Regards,
Ayush Sharma
Brian TIDAL
your T2T tag is probably not NDEF formatted and therefore the ndefPollerNdefDetect fails to find the Capability Container. I suggest to check the content of Block #3 (it should start with E1 10 .. ..). You can use ST25 NFC Tap on an Android phone to check the content of the block #3.
Rgds
BT
1 REPLY 1
Brian TIDAL
Rgds
BT
