2021-03-01 08:13 PM
CubeMX has a number of templates for discovery boards but there doesn't seem to be one available for the ST25R3916 Discovery
2021-03-08 09:11 AM
Hi @BC1 ,
The ST25R3916-DISCO Kit comes with application notes, software applications, drivers, BOM (bill of materials), board schematics, Gerber files and firmware schematics.
But there is not an available template/example in STM32CubeMX developed with this kit.
Actually, ST provides you with the STSW-ST25R010 PC software installer for ST25R3916-DISCO containing the ST25R3916 Discovery graphical user interface (GUI) to control the ST25R3916-DISCO board from a Windows PC.
Here also the Firmware for the ST25R3916-DISCO board User Manual demonstrating the capabilities of the ST25R3916-DISCO board and the Data Sheet of ST25R3916.
Hope this helps you .
Khouloud.
2021-03-08 09:11 AM
Hi @BC1 ,
Khouloud.
2021-03-08 12:55 PM
Hi Khouloud,
In the end I ended up manually converting the provided example firmware to a Makefile project as the provided TrueStudio project doesn't build even on a clean install of Windows 10. This has solved my problem for now but it would be good if this dev board had a template for TouchGFX to make it easier to change the UI.
Thanks,
BC1
2021-03-09 05:52 AM
Hi @BC1 ,
Happy to know that you have found a workaround to your problem :smiling_face_with_smiling_eyes:
And because your ideas and suggestions matter, it is more efficient to add it in its right space in the Community, the Idea Zone. Your proposal will be reviewed by ST product teams to see how to improve the provided solutions.
Thanks for your contribution.
Khouloud.
