2021-01-08 7:04 PM
Hi ,
is there any user manual " how to connect ST25RU3993 UHF module via raspberry pi "
please send if any documents
2021-01-21 10:05 AM
Cedric,
I am just unzipping the 2.3.0 SDK content and opening the solutiion in VisualStudio 2019. The includes shown are the same that I am seeing right now.
I am installing VS 2017 to check if works in this case.
2021-01-22 7:22 AM
Cedric,
Just the final update. Finally the example runs OK using VisualStudio 2017. Something fails using 2019 version.
Thank you
Best Regards
2021-01-22 7:30 AM
Hi Franco,
thanks for the update.
regards
Cedric.
