2020-01-24 12:30 PM
2020-01-27 01:38 AM
Hi Dmate,
I made some trials with iPhone7/iOS 13.1.2 and ST25TV02K completely new : NO DEFS, NO CC File (block 0 set to 0x00 00 00 00).
With iOS NFC Tap V2.1 (version from Apple Store https://apps.apple.com/fr/app/nfc-tap/id1278913597) :
In this tag configuration, you can only write a correct CC File in block 0. For ex : xE1 x40 x08 x00
I will try again with iOS13.3 to be sure that there is no regression with this release.
Please, could you send me a dump of tag memory (by using another app or reader ) ? at least 10 first blocks ?
Thx and br,
2020-01-27 01:38 AM
Hi Dmate,
Thx and br,
2020-01-27 05:17 AM
Hi again Dmate,
So, I have retried with iOS13.3.1/iphone7/NFC Tap Apple Store , and behavior is same as described in my previous answer.
If block0 does not contain valid data, Tag is always detected when hitting "Read Tag" button.
For NDEFs read/write , you MUST at least have an empty NDEF after CC file. This is requested by NFC forum normally.
Please, let me know.
Br,
Vincent
2020-01-27 05:08 PM
2020-02-11 01:05 AM
Hello DMate.1,
Can you indicate which module you are using exactly, please ? On which antenna is mounted ST25TV02K-AD6H3 chip please ? Where have you ordered it ?
Best Regards,
BB
