2019-10-10 04:34 PM
I want to use ST25R3916 in our bank card NFC reader.
There can i find example code for X-NUCLEO-NFC06A1, that implements Tag detection, Anticollision, SELECT, RATS, APDU...?
2019-10-11 12:27 AM
the https://www.st.com/en/embedded-software/x-cube-nfc6.html is the support package for the the X-NUCLEO-NFC06A1.
As you mention banking cards, if you actually target EMVCo compliance ST does also have an explicit demo board for EMVCo (similar to https://www.st.com/en/evaluation-tools/st25r3911b-emvco.html).
Regards, Ulysses
2019-10-11 12:27 AM
Regards, Ulysses
2019-10-14 06:39 AM
Hello! Thank you for the answer!
Where can i find complete ref. design with CAD files for https://www.st.com/en/evaluation-tools/st25r3911b-emvco.html?
2019-10-14 08:04 AM
for getting the support package you will need to go through your local ST support team.
BR, Ulysses
