2018-01-18 07:27 PM
My Samsung mobile upgraded from Android 6.0 to 7.0. But after that the 24SR seems can't detect from mobile NFC.
It happens only after the 24SR IC locked in read/write. For unlocked the chip by 24SR discovery board hardware, 24SR can detect by mobile again. I tested in Android 4.4,5.0 and 6.0 and all work. So is there any changes in Android 7.0 that cause this problem ? Please advise and thanks.
2018-02-12 03:39 AM
Hi Sunny,
The iOS source code is available on demand. Please contact our local marketing engineer to get access to the code.
Regards,
JP
2018-03-21 12:13 AM
Would you pass ios app source code to HK ST office?( I have contacted HK Array electronics)
Best regards
Sunny.
2018-03-26 11:10 AM
yes definitely. Please ask the HK ST office for the iOS application source code. We'll be happy to provide it to you.
Please be aware also that we are a few days away from having it published on st.com
Best regards
JP
2018-03-28 10:58 AM
Thx a lot
在 2018-03-27 00:12,JP Miller 写�?�:
STMICROELECTRONICS COMMUNITY
RE: ANDROID 7.0 PROBLEM IN LOCKED 24SR
reply from JP Miller in ST25 NFC/RFID Tags and Readers - View the full discussion
________________ Attachments : blocked.gif : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006HxrE&d=%2Fa%2F0X0000000b1Q%2FgXyxZZQOt4kSuv.wlebR37oiVPMVe3rWj6wY76K_Pas&asPdf=false2018-04-25 09:33 PM
Dear All,
As my Android NFC Apps can read /write and manage password with ST tag IC , may I know how can submit ST
team for trial or testing ? which person can i sent the Apps link ?
Thanks and best regards
Sunny.
2018-06-04 07:18 AM
iOS ST25NFC Tap source code is available under
http://www.st.com/en/embedded-software/stsw-st25ios002.html
Hope it helps.
Br,
VL
