2024-09-23 05:33 AM
Hi. I have purchased
I am using a c2000 (F28379d board), the driver board is only giving me a lower side pulse. Can you please help me.
2024-09-25 12:41 AM
there is issue in the driver board which I am not able to understand. please help me
1 when in give both the LIN and HIN, I do not get any out put from the driver board
2 when I remove either the LIN signal or HIN signal the lower I get out from the LVG
I have already tried all the possible solution like dead time, continuity test, supply connection etc.
please provide the solution, its little urgent for me sir
2024-09-25 05:32 AM
Sir, please look into this matter, its quite urgent sir..
2024-10-01 05:25 AM
