mosfet stp5nk50z
‎2018-03-13 10:21 AM
Hello
I am looking for an equivalent of the mosfet stp5nk50z to 220 for a Rolling shutter, thank you
Motor Control Hardware
‎2018-03-14 4:03 AM
why ?
best to use the right part.
https://www.digikey.com/products/en?keywords=stp5nk50z
if you need a better unit we can work on that.
‎2018-03-14 10:36 AM
This component is hs and it is no longer available except the Stp5nk50zfp new to electronics, I need to know if it can be mounted instead
Thank you
‎2018-03-14 5:44 PM
The Z part is available and the ZFP part is available but not recommmended for new designs.
yes either part can be used,
however on the ZFP part the tab is not conductive.
check if the PCB has the TAB connected to pin 2.
if the PCB has this connection, either part can be used.
‎2018-03-15 10:39 AM
If The Z part is available It would be better to choose it but I can't find this reference on the site st.com to buy it
thank you
‎2018-03-15 3:25 PM
I gave you the link above,
it has both parts available.
