2024-07-03 09:53 PM - last edited on 2024-07-08 07:51 AM by Peter BENSCH
Hi i'm looking for datasheet and replacement of GP429. Can someone help please ?
2024-07-03 11:41 PM - edited 2024-07-03 11:45 PM
Welcome @akarapol, to the community!
the marking is SUG, which stands for the discontinued SMA6F13A.
If you need to repair something, you could replace them with the SMA6J13A.
Hope that helps?
Good luck!
/Peter
Hope that helps?
Good luck!
/Peter
