LM317T vs LM317BT
ZSu.1
What is the difference between LM317T & LM317BT?
4 REPLIES 4
DFuchs
difference is the allowed temperature. B is for industrial use -40 to 125°C
Kind regards
Daniel
ZSu.1
Daniel,
Thanks for the clarification. Does LM217 has same electrical characteristics as LM317 but with higher thermal sustainability to 150C?
Regards,
David
DFuchs
It seems to me that LM217 and LM317 have the same characteristics, expect the -20 to 150°C
Always have a look at the datasheet: https://www.st.com/resource/en/datasheet/lm317.pdf
Kind regards
Daniel
ZSu.1
Thanks, Daniel. Just confirm it further.
Regards,
David
