2015-03-26 10:53 AM
I believe there is an error in the L6482 data sheet. The Register Map indicates a 10-bit wide FS_SPD register. However, the detailed description of the FS_SPD register describes a 12-bit wide register, Bit11 being the boost bit. When I set bit11 and read it back it always returns as 0, suggesting that the 12-bit wide definition is incorrect.
So what is correct? Is bit9 the boost bit and bits8-0 are the switch value? #l6482-fs_spd2015-04-01 11:48 PM
Ciao
Try to ask in this . Ciao Gigi
