L6470 WITH UNIPOLAR MOTOR
Options
‎2013-12-16 12:50 AM
Posted on December 16, 2013 at 09:50
I use ST L6470 with unipolar motor.
L6470 is biplar type dirver, so I unconnected com line of unipolar motor. motor spec is below: MAKER: sanyo denki type : 103H5210-0480 1.2A/1.8DEGREE/3.3OHM. because unconnected com line, resistor is 6.6Ohm. I apply DC24V in the motor. The problem is that motor is not reached 1500PPS. under 1000PPS, motor is well opeared. Is it problem thar unipolar motor is used not bipolar? I changed all variable factor(acc,dec,kval, etc...), but it reached 1500PPS. what is wrong? #d
Labels:
- Labels:
Motor Control Hardware
4 REPLIES 4
Options
‎2013-12-16 4:37 AM
Posted on December 16, 2013 at 13:37
Unipolar motors can usually also operate in bipolar mode. Your issue could be related to resonances. Please, try the following: - Set the full-step speed (FS_SPD register) to the maximum. Voltrage mode driving gives best results in microstepping operation - Add a small mechanical load to the motor shaft in order to shift the resonance point and dampen the vibration. Regards EnricoOptions
‎2013-12-16 6:38 AM
Posted on December 16, 2013 at 15:38
Options
‎2013-12-16 6:41 AM
Posted on December 16, 2013 at 15:41
Options
‎2013-12-19 11:26 PM
Posted on December 20, 2013 at 08:26
did you try to add a mechanical load on the motor shaft? This could be a resonance issue. Regards Enrico
