I would like to know what is the current consumption of STSPIN32F0A when it is operated with a 48MHZ crystal.
sDora
The data sheet is not specifying this information , Pls. let me know the current consumed by the MCU @ 48MHZ
cedric H
Dear User,
STSPIN is based on STM32F0, power consumption does not only depend on the MCU frequency. You need to take into account the complete clock tree configuration. Could you detail a litle bit more the use case you would like to achieve. Most of the time consumption of the MCU is not a top priority of the motor control application.
Best regards
Cedric
