How to set load capacity for L6470?
I m using L6470 which is working fine without load, but when load is applied the motor stuck. Which parameter i should consider for it?also how to reduce stepper motor noise?My current configuration are like thiswrite_buffer[0]=CMD_SETPARAM |REG_MAX_...
