Driving both channels parallel on vnd products
rkager
We have multiple VND5160AJ-E on a new product were we use every single channel as an output channel. Some outputs should driver 4 Ampere which would be perfect doable if we run both channels in a chip parallel. So are the any concerns about doing this if both IN Pins are driven bei a single MCU output and the OUTPUT pins are connected all together?
0 REPLIES 0
