Close this topic...move to other place.
ausera uirwaij
Thank you.
22 REPLIES 22
Could you probe with the oscilloscope the ADC inputs of your MCU so we can see the true BACK-EMF the mcu is actually seeing?
>>Is any possible suppress or discharge back-emf voltage by hardware?
yes, how are you sensing the back-emf?
hit me up in https://www.linkedin.com/in/javiermu%C3%B1oz/
Hi @Cristiana SCARAMEL​ , are you OK?
Hope you can reply when you're convenient.
Thank you.
Hi @ausera uirwaij​ ,
from your discussion with @Javier Muñoz​ it seems you want to compare systems strongly different.
I agree with him with the suggestions to fix current spikes.
Moreover I am a dedicated expert for ST motor control hardware.
In the two solutions described there are no ST gate driver or motor driver to support.
I don’t know how to help you, I don’t know the competitor ICs.
Finally the subsequent requests are outside the main question for which the topic was opened.
If you feel a post has answered your question, please click "Accept as Solution"
