2025-03-05 2:04 AM
Can I find the manufacture year from the bulk ID? Most of ST parts only indicate the last digit of the year, sometimes we just don't know it is 2013 or 2023.
2025-03-05 2:15 AM - edited 2025-03-05 2:16 AM
Welcome @davidousz, to the community!
In fact, you can only identify the decade with the help of the delivery note.
If you only have the bulk ID (please do NOT post it here to prevent misuse), then you should ask your dealer, because it doesn't contain the date code.
Hope that helps?
/Peter
Hope that helps?
/Peter
