About L6562A operation. Is there a possibility that the IC will breakdown if it is operated above the recommended fswmin value of 20 to 50 kHz described in AN2761?
貴藤井.1
Peter BENSCH
No, the frequency range mentioned in AN2761 is just a typical range.
Limiting values of devices can always be found in the datasheet.
Good luck in designing your device!
/Peter
貴藤井.1
Dear peter
Thank you for your reply.
I understand what you said.
I'll continue designing circuit Paying attention to the limitting values of data sheet.
Sincerely,
Takahito
