mbed Serial on Nucleo UART4
2015-08-12 4:14 PM
I have already asked this question on the mbed site:
https://developer.mbed.org/questions/59656/Serial-What-are-the-Supported-pins/
It isn't clear from the Handbook whether this is even supposed to be supported. I tried instantiating as:Serial uart4( PC_10, PC_11 );
But is seems that can't be sufficient, as USART3 can also use PC10 & PC11 - so how could it know?!
#fail #nucleo #nucleo #uart #mbed #possibly-worst-forum-software #serial #keil #mbed
- Labels:
Keil
Mbed
UART-USART
2015-08-12 5:27 PM
Well the ST-LINK VCP is definitely USART2 via PA2/PA3 on the
https://developer.mbed.org/platforms/ST-Nucleo-L152RE/
But somewhat irritatingly that conflicts with the D0/D1 of the header.I'd have to wade through the manuals for USART3/UART4, but I could swear you'd have to manually modify the board to get those to the VCP TX/RX pins.Up vote any posts that you find helpful, it shows what's working..
2015-08-12 5:38 PM
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM001058pdf
2015-08-12 5:46 PM
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/datasheet/DM00098321.pdf
UART4 would also be viable on these pins, if you really needed to use USART3 somewhere else and in synchronous mode. With 64-pins I find that a tad improbable.Not into mbed myself, but would suspect calling out the U(S)ART and specifying the pins to select as AF, should be enough for the magic inside the board/chip support code to get the chip set up properly, provided you'd dealt with the wiring externally.Up vote any posts that you find helpful, it shows what's working..
2015-08-12 11:39 PM
Sorry - I'm not talking about the
ST-LINK VCP here at all.
I have serial comms with the PC over theST-LINK VCP working fine.
What I'm looking to do is to also have UART (or USART) comms on the header pins.The UART4 pins seemed initially convenient - but any other pins would do.I'm also not much into mbed (yet) - but the documentation on this does seem very skimpy (being kind).:(A complex system designed from scratch never works and cannot be patched up to make it work.
2015-08-13 10:06 AM
I've use PA9/PA10 USART1 before.
PA10 (D2) USART1-RX is usable for GPS shield.The Morpho header has more opportunities.Up vote any posts that you find helpful, it shows what's working..
2015-08-14 2:47 PM
Experimenting further, I can successfully printf() to UARTs 1 & 3; but printf() to UART 4 or 5 hangs.
#include ''mbed.h''
// Hyperterminal configuration
// 9600 bauds, 8-bit data, no parity
Serial pc(SERIAL_TX, SERIAL_RX);
//Serial uart1( PA_9, PA_10 );
Serial uart1( PB_6, PB_7 );
Serial uart3( PB_10, PB_11 );
Serial uart5( PC_12, PD_2 );
DigitalOut myled(LED1);
int main() {
int i = 1;
pc.printf(''
Hello World !'');
while(1) {
wait(1);
pc .printf(''
SERIAL_TX: %d.'', i);
//uart1.printf(''
UART1: %d.'', i);
//uart3.printf(''
UART3: %d.'', i);
uart4.printf(''
UART4: %d.'', i);
//uart5.printf(''
UART5: %d.'', i);
i++;
myled = !myled;
2015-08-14 3:57 PM
Yeah, I'd take a look at the board support code, and make sure it's enabling the right APB clocks for the USARTs
2015-08-15 4:03 AM
Yes.
The online compiler seems pretty useless in getting to see that, and exporting seems to be broken at the moment.A complex system designed from scratch never works and cannot be patched up to make it work.
2015-08-19 4:43 AM
Thoroughly cheesed-off with mbed, Keil, and Nucleo at the moment!
:(As noted, the debugging and browsing in the online compiler is pretty useless; so I thought I'd export to Keil.But the mbed Export function is not working - everything is just stuck in the cloud.:(I eventually found a way to export something, but the Project does not build - and Keil's error message is unhelpfulhttp://www.keil.com/forum/60126:(I did finally get the project to build, only to find that it doesn't have theboard support as source code anyhow - so useless for debugging this issue!!
