Where to get TDB0791EP datasheet
jl4
Could you help me with the data sheet for the: "TDB0791EP"
Peter BENSCH
@jl4 I no longer have any information on the TDB0910EP because it was discontinued in the last millennium. However, if you are looking for a replacement in an existing system, you could check the schematics to see if the TDB7910 (long obsolete, too) might be comparable or identical, which just doesn't have the cooling wings of the TDB0791EP.
/Peter
4 REPLIES 4
If you go there, this component is not there
other datasheet sites are available.
also various distributor sites have datasheets ...
Peter BENSCH
/Peter
